Great information thanks for the post. It’s hard to teach a newbie over the internet what takes entire libraries and years of experience to comprehend but hey we’re all trying our best to help.If you have any more ideas of what may be his problem please add them I’ve run out of things that could be the cause of his non charging grrrr
In 50 years of rving I’ve evolved from wet flooded lead acid to agm now LiFeP04 and never going back
Nice sparky chatting with fellow engineers.
John T long retired EE
My only "newbie" warning comes from a side job that I had, fixing those powered wheel chairs that many people have.
The wheelchairs used 12V Lead-acid marine batteries, just like boats, RVs, etc. Most of them, had a charge indicator that was just something like four dummy lights based on voltage, like a gas gauge.
What confused a bunch of users was "voltage rebound." They would be using their wheelchair around the house, it would say that the battery was no good. They would shut the wheelchair off. Then turn it back on. The dummy lights would now say that the battery was good! Even without putting it on the charger!
They would then start down the sidewalk (as they often used the things like ATVs), to the store. And about 25 yards from home? Battery no good again...
And sometimes, there they were... unable to walk home...and unable to drive home, because the little controller/battery gauge said the battery was bad... then they would turn it off and on again... and maybe get half way home... rinse/repeat.
When batteries get bad or weak, their voltage will drop under load. Then, if you unload it... the voltage may rebound... and a dummy light, or multimeter voltage measurement looks fine... but that voltage will drop like a lead balloon as soon as the battery is loaded again. (and I know, you know that...)
But the average everyday user?
I don't know how many of them told me that their batteries were fine...they needed new chargers, or controllers; "because it says the battery is good, if I just turn it off and back on again...the controller must not be reading the battery right"
A multimeter voltage measurement, or a dummy light... can only tell so much.
