Texasmark1
1963 4 cyl 2000, RoosaMaster DB6 VCC_______ top distributor pump. ON the side of the distributor housing, is the inspection plate for checking timing
and below that is the ID plate. Beneath the ID plate, lower left corner is a tall, Brass, Acorn nut that I think.....but not sure and need to be sure.....is the
bleed screw.
The manuals for it and for hundred series tractors go into pretty good detail about how to change the filter and that part is a no brainer and done, and
mentions bleeding the pump including opening the bleed port and crank the engine through a few times till you get solid fuel flow, then close it off and
crank her up, but no pictures.
Also, one would suspect that the throttle needs to be wide open when cranking during the bleed process. I don't want to have to go to each injector and
crack the fuel line. I feel this would be unnecessary since the tractor hasn't been rolled over or moved since I shut it down and popped the filter. The
less I touch the less the opportunity for a 45+ year old tractor to have something break......and my pump was running just fine and surely don't want to
mess with the wrong screw and generate a problem with it.
As usual appreciate your help.
Thanks,
Mark
bleed screw.
Thanks,
Mark
