FOMOCO Farmer
I have been fighting this for a while. I bought a kit from this website, honed the master cylinder, installed the kit, and still no luck. Repeated the process with same results. The piston seems to be
sticking in the master cylinder. All the holes are open inside. I cannot get anything to the bleed screws. I'm using the New Holland brake oil. Any ideas? Thanks!
I've got to get fluid to the bleed screws to see if the seals in the piston need replacing.
