I have a IH brush cutter my grandsonson was using my utility 300 with the brush cutter out back cutting down tall weeds, he didn't let the cutter down where the trailing wheel was on the ground which I believe caused the yoke which is attached to the gear box to get ripped out, the cutter is a IH L1, it has a plate attached to the gear box and has 2 bolts going into the main shaft of the gear box, the yoke plate attached to the yoke is junk as is the yoke. Is there a way if I can use a different set up, instead of trying to find the original parts, or where I could find any original ones. The cutter is a 5' wide cutter and made by IH. Hope some one can help.
