On my 1030 the hydraulic pump is starting to whine like it is low on fluid. It is not low on fluid, it's actually a bit overfull. I changed all the hydraulic fluid about a year ago and used Hytran in it.
Does the whine mean there is a screen on the pump pickup that is partially clogged? If yes, is there a way to get to this screen without pulling the pump assembly?
Or does the whine mean the pump is starting to go bad? I've not checked pressures, but the three point and remotes still work fine. At least they still do what I need done.
