Case 930 power steering
nramike
I have a case 930 with a power steering leak at the high pressure hose connection to the unit not the pump there is a brass fitting inside the the hose tightens up to does any one know how or if it comes out thanks!!!
It does come out. I would guess is its the
hose tho, but the brass piece could have
been damaged some how. I had to replace
that on my 1030 last year, I had one made
for hydraulic hose. Don't make the mistake
did the first time and get one too small.
I bought based on outside diameter and
that was too small inside and caused the
oil to heat. To get everything to work I
had to use a series of fittings and brake
line to make all the bends then convert to
hose. In the end it works well and looks
ok.
