I have a Cessna Power Steering pump on my 1963 Oliver 550. The Cessna Mod# G 20436 OEFY. It is leaking oil out the front shaft. It appears to function properly and after opening it up I think it needs a seal kit for the center of the pump. Not sure if the bushing the shaft rides in is a problem but it looks good and clean. Gears looked great! Does anyone know where I might find these seals? It also had a copper type thin plate in the center that had some scratches/wear. I need some of you to give me your advice on what your recommendations would be? Is there a modern replacement pump available if I cannot fix this one? Thanks Chris.
