Ford 821 Mutt
I have a Ford 821 (mutt no backhoe replace with 3pt hitch). The clutch needed to be replaced so I purchased a new 10" clutch system plus bushings, release fork plus shaft, bearing hub and springs. In removing the release shaft the clutch lever arm at connects to the pedal was welded to the shaft and "clocked" to a lower position.
Since I replaced all the old parts with the new and used the template to set the bolts on the clutch fingers the adjustment is max out and can barely shift in gear. I noticed that when I mounted the clutch and pressure plate that after torquing it down, the fingers retracted deeper than what I thought was correct. This would cause the adjustment to be at the max (see picture). It would seem that the 10" disk should sit in a "pocket" on the flywheel or some kind of "stand-off" shims for the pressure plate. I put my phone in the starter mounting hole and you can see that the bearing is well down the support with the peddle up and at the max adjustment.
Thanks for any help or insight in solving this issue.
Ford 821 Mutt
Ford 821 Mutt
