Anonymous-0
model 801 1959 gov. indust. ford tractor front end loader and backhoe.The clutch pedal was depressed for 2 yrs. so as to not let the clutch plate get stuck. As a result, everything works, but i cannot get it to move into gear. It appears the fingers may be stuck. I can see the spring as i depress the clutch. But it does not appear to move me into gear. I have attempted various adjustments on the clevis and the freeplay in the pedal itself to no help. Is there anything i can do. I have pulled the starter and attempted to spray different lubricant, but h as not worked. I have used the front end a back to move the machine a few ft., but that has not helped. Any suggestions short of splitting the machine. Thanks!!
