Coal for fill????
Anonymous-0
Hey folks,
I've got a cellar under the barn that I may be able to spend a little time on this winter. The floor is 2/3 paved with bricks and flat/sloped a little to a drain but the 1/3 on the end where the drain is has been dug in and has a pretty low spot that collects ground water when the weather is wet.
Haven't been in there in a few months and today there was no water collected. It's still wet outside, maybe a shift in the ground water (??). Anyway, someone before us used to store coal in there and there is a bunch that I was going to throw away (it's egg shaped pieces) and then thought I'd just use it to fill in the low spot tamp it and spread a couple inches of gravel on the whole floor with a bucket and pump set in the place where water used to collect with a hose running to the drain. Then, maybe I can get some use out of the cellar. With coal being in the ground for millions of years, it should do OK to fill the hole in my basement shouldn't it?
Thanks, Dave
There may be several people willing to trade you for road base #6 gravel. Even a good clay would be better than the easily compressed and still flammable coal. Trade even if they take it away, and deliver. Coal does not compact to a stable surface. It remains dirty in many ways. It may be charcoal, or coke, if the nuggets are regular, it is probably not coal. If it is charcoal or coke, it is even more valuable for someone doing forge work, as it is capable of heating iron to working temp much better than coal. Jim
Figured the stuff wouldn't be any good because of all the moisture. If I take it out and lay it out on the barn floor a couple days it'll still burn? Probably 300 pounds or so.
Dave
If it is coal, doesn't matter how long its been wet, when heated it will burn. Charcoal? it all depends on how good a quality it is, charcoal briquettes for barbecue are a distant cousin to real charcoal as used by glassmakers, cooking, and blacksmithing. I do blacksmithing, with coal.
Dry carbon is dry carbon. It will burn just fine.
spread it out and dry it. Try a few briquettes in a grill after they dry, Light them with a propane torch. I would sell them! Jim
