Absent Minded Farmer
- Location
- Gehl Country, Wis.
Gonna try this again....
Yes, it looks like there should be a fuel pump where the plate is. There's a support for a pushrod near the cam area. I couldn't help but poke at the drip on the bottom of the support. I was amazed that my fingernail left a mark!! I don't know what kind of goo it was dipped in, but you can do that to most of the drips on the block. Which brings up my first important question: what needs to get done to prep the block for assembly? I'd wager it's a little more work than Dawn & a scrub brush. Also, what is the significance of the "C" on the oil pan flange? Some kind of bearing size?
Now, the skinny on this project. The engine will eventually end up in my '42 H & power my mower & hay conditioner. It looks like a Firecrater set (@ Weber's) is in order for this job, but I just don't know if I want to keep it a 169 or bore it to a 175. I may leave it. The 47 predicted HP for the 169 with the Firecrater set should be plenty enough power for the job. The H was stock & 26 HP was ok in average hay. The armpit high 1st crop we had this year was a bit much for it. The blasting medium in the engine may not have been much of a help, either.
Mike
Mike
