Hope you aren't planning on letting him borrow anything else! Throwing away parts that broke to a borrowed item is a big red flag to me, family or not! Stuff happens but some parts are not easily replaced with new but may be rewelded if need be.MIne has the check-chains for the coulters, the tiny scrapers for the coulters, and slatted moldboards. Loaned it to my BIL and he said he hit a rock and broke the coulter shaft, then threw the broken-off coulter away_. I also have a new set of points set back.
My single bottom Ford 110 coulter finds & cuts its own path in front of the plowshare.you mean the check chains, the economy plows didn't have those, if you wanted I suppose you could get a newer coulter assembly with an anti sway system or universal coulters. so you don't need chains
Yup. He died about 6 years ago from the effects of Agent Orange, so that ended the borrowing. A new coulter is NLA, so the used market is my only source. I've never gotten around toit though.Hope you aren't planning on letting him borrow anything else! Throwing away parts that broke to a borrowed item is a big red flag to me, family or not! Stuff happens but some parts are not easily replaced with new but may be rewelded if need be.
I believe that one is an early Ford 101.I have this one for sale now- the one we had when I was a kid said "Dearborn", this one says "Ford"
Cool photo!View attachment 156167
I had a Ferguson 2-14 that I used behind my 8N, but removed the coulters pretty quickly. I was plowing down corn stubble, and they plugged up easily. You can see a small chain hanging down in the photo, and I suspect it was indeed a check chain for the front coulter. The rear chain must have already been missing, or perhaps was deemed not needed by the manufacturer.
They were Red in the 1950s - after 1962 they were Blue and had trip bottoms.
I've had a later 101 (2-16") with trips and coulters for 15 years at least.
Had a few Dearborn and Ferguson plows in the past. Can't recall any of them having check chains on the coulters. I don't think they ever did but could be wrong.
Coulters are nice for cutting sod. If you are plowing every year you really don't need them.
So what I’ve learned from reading, don’t loan my tools or tractor to anyone, and always look for a missing coulter,
Even a small pic not sending, but the 14A has the chains and is very similar to the top pic AO 28 from Ray other than a left and right vertical strut is cast. Marked as Ferguson, Ferguson Sherman Manufacturing. Dearborn Mi.14A #15080. 39 thru 41. Cast uprights. May be late 1940?? Picture would not send. Will try later
I have been looking for a 2 bottom 3 point plow. I have seen some Dearborn plows that don't have chains to center the coulters and keep from damaging the tires. Do all Dearborn plows supposed to have chains?
