The Famous Grouse
Guys, I've got a Deere 2010 wide front and today things really came undone.
I broke the rear support (key 18 on diagram).
https://partscatalog.deere.com/jdrc/sidebyside/equipment/82370/referrer/navigation/pgId/268323
Upon further examination, the part has obviously been brazed together before. Possibley several times. Hopefully I did not do any major front end damage when things cam apart. Everything looks ok so far, but a couple of questions.
1. Was breakage of this part a common issue?
2. Biggest question is the parts diagram shows there is a bushing (key 17) for both the front and rear support.
I did not see any bushings when I took everythig apart. Can someone confirm these bushings actually fit inside the front and rear support and then the axel pivot slips inside the bushing?
Also, could these bushings have worn out and disappeared over time? I did not see them inside the front support nor did I find one on the ground that could have come out when the rear support came undone.
3. Last question: Who is likely to have these parts in MN or western Wisconsin? Or other good mail order sources where I could get it fast.
Really need this tracor fixed. It's food plot season, I'm running behind due to weather, and I gotta get planted.
Many thanks guys, all help appreciated.
Grouse
Grouse
