Diesel in Crankcase
mlauk
I'm getting diesel fuel in the crankcase oil on a Ford/New Holland 3010S. Replaced the fuel pump and disconnected the thermostart, but still adds fuel quickly. The tractor runs and starts good with no smoke, so I think it is a seal on the Bosch VE3 injector pump. Is this an easy to fix or should I bring it to a pump shop? Thanks
Might just need the seal or MIGHT also be the shaft bushings are worn so drive shaft is no longer centered in the seal. If tractor has several hours, it would be wise to have the complete pump gone through.
