grandpa Love
Can I use this meter to check voltage from the coil to distributor on my Fords and cubs? Most are 12 volt. Some coils ain't marked if the have internal resistor or not. If I can use it what do I set it on?
ell, grandpa, my heart goes out to you, because if you came here confused, you will go away either more confused or feeling insane, as there is a lot of bogus/conflicting stuff/opinions expressed here. I need to write a book to address each one & do not intend to. I will try to help a little.(quoted from post at 09:13:25 07/16/21) GP,
There's only one problem with that old school analog meter.
They are not fool proof.
You get the polarity wrong, the meter will go backwards and bend the pointer.
You connect the meter to voltage when on the resistance scale, the smoke will leave the meter. Ask me how I know?
Your meter is better than some digital meters when measuring charging voltage.
Some digital meters will dance all over because the charging voltage isn't steady.
When your points are open, you should get full battery voltage on the + of coil.
When your points are closed, you will get less than full battery voltage because some is used by ballast. My rule of thumb, 6v on coil and 6v on ballast will usually mean 4 amps in coil. Your meter can't measure 4 amps. 250 ma, quarter of an amp.
If you have negative ground, the voltage at coil will be positive.
BE CAREFUL, you get the polarity right, Use the largest voltage scale to prevent banging the pointer is you get the polarity wrong.
Another negative about they meter, It doesn't respond well to gravity, dropping it.
Keep it in a clean place too. Metal particles will find their way to the magnet in meter movement.
Good chance you make one mistake and the meter won't forgive you.
