I have a 1978 Farmall 140 (12v system) that has started doing weird things! It started off with the tractor just shutting off Iile youd turn the switch offI changed plugs, points, condenser, coil, plugs and plug wires! Problem solved.now when I start the engine it will not turn off with the key! If I unplug the lower wire of the external resistor that is mounted to the alternator I can crank and shut the engine off from the switch! I changed the resistorit still does it! I tried to run the wiring schematics on it and thought maybe that the ammeter was bad since it runs through that! Replaced that and still will not shut off!!! Any help would be appreciated!!
JP
JP
