oregonfarmer
My Farmall 200 has a problem. I was driving it when it kind of sputtered a
few times and then stopped, and it will not start again. I checked the
timing and wires, etc. I had a new distributor and installed it and that
did not solve the problem so I checked the coil and I have 6.2 volts going
in and the coil reads 3.9 ohms from terminal to terminal. Everything
appears to be all right but I still have no spark. This is a positive
ground and I have one wire from the battery to the positive (+) side of the
coil and the negative (-) wire goes to the distributor. I'm not sure what
is wrong.
is wrong.
