I'm trying to get my F350 in shape to be the reliable workhorse that was my H. The 350 had been converted to 12V with a 3 wire (? Delco Si) alternator. There is an output terminal on the back and a two lead plug on the bottom.
One lead (white) for the two wire plug comes down from the output terminal on the back, goes through a diode to terminal 1 on the alternator. The other (red) comes from the + side (not the points) of the coil. The red wire (coil) goes to terminal 2 on the alternator.
The problem is that a lead for the diode snapped off. Being way behind this spring, fixing this did not come to the top of my to-do list (the H was working fine). Now...
I have been making do by touching the broken diode lead to the lead on the other side of the diode. Until now that would power up the stator and recharge the battery. That's not working anymore.
What should I be looking at to diagnose the problem ? Just bad brushes ?
Greg
Greg
