farmalldave
Hello I have a Farmall bn that just recently started having a tapping sound coming from the transmission. The sound is hard to locate at times it sounds like it's coming from the left side of axle. I removed the transmission shift cover and found a looks to be tooth stuck between some gears. I removed that and changed all gear oil. I started it back up and was able to drive it after removing the tooth in the gear. While driving it the sound returned and the engine stopped running. The battery is new and the tractor engine acts like it is seized up. Although when I push in on the clutch the engine spins just fine like it did before. The engine has good oil. What could this problem be where do I start in trying to find the problem to fix it. Thanks
