Farmall BN problem today
kshansen
I have not figured this out yet but think it maybe a major problem!
I've had this tractor since late 70's or early 80's right now I can not find date on when I did a major over haul just guessing it was in the mid to late 1990's. By major overhaul I mean it was stripped down to bare castings from front to back!
Well today was using it to move a load of fire wood back to the wood shed from where I split it. I needed some gas for the splitter. Shut of the tractor and went in shed to grab gas can. When I went to start tractor it fired a couple time then stopped. At first I though it may be out of gas but checking that there was a couple inches above the bottom. Also noticed it seemed to be cranking a little faster than normal. Just for kicks I took the magneto/distributor cap off and hit the starter. Not good as the rotor is not turning!!!
As I did not feel like getting involved with major work decided to use starter to crank it over and move it into the shed, only 10 feet away.
A hot day and my energy level is too low to go any further right now. I'm thinking the first step when I have some ambition will be to pull valve cover and see if things seem to be working in there. Depending on what that shows will determine next step.
