Ok guys my Cub decided toady that it was not going to let me put it into gear. When I step on the clutch pedal it will not go in far enough to let me put the tractor into any gear. I can tell it is close to letting me but it will not. I put a new throw-out bearing in about 3 years ago and when I put the tractor back together the pedal was just not adjusted like it should have been but I decided to let it go, because I did not want to split the tractor again. It worked but I only had about 1" of pedal to disengage the clutch. Like the pedal went almost to the floor and the last 1" worked for about 3 years. Now if it is not something I can adjust through the hole on the bottom and I have to split the tractor again what is the best way to make sure it is right before it goes back together.
Thanks guys... I am not getting any younger
Steve
Steve
