steave1288
Hello all... I have a 1956 Farmall cub all original and still 6 volt... My question is, with the ignition on (ignition switch out) should I have power at the distributor wire... ( wire from coil to distributor) also... Second question: With the ignition on and a test light to ground should the test light light when I touch the distributor housing? and if it does that would mean the distributor wire is grounding against the distributor housing, Correct? and finally... what side of the coil should the distributor wire go to + or - Someone has had their hands in this tractor before me... So I am not sure everything is hooked up correctly... Thank you..
