When I start the F-12 the oil pressure is great. Over halfway up the gauge at low idle. After running the F-12 for 10-15 minutes and the oil heat up the pressure drops to right at the top of the red at idle and just above at fast idle. All the other Farmalls we have keep good oil pressure no matter what. I have completely cleaned the oil filter housing, put on new gaskets and made sure there is no leaks. Is the next step to replace the gasket on the oil pump?
Thanks for the help. Before I drop the pan again I want to make sure I'm going about it the right way since take the pan on and off is such a pain with it. Anything else I should check if I take it off?
Thanks,
Noah
Thanks,
Noah
