Hi everyone,
I am making more progress on the F-12. I took the valve cover off and noticed while cranking that the exhaust valve on 2 and 3 were stuck. Luckily the push rods weren't bent. It was a tight fit but I was able to get the push rods out. I worked the valves for an hour and got them freed up with a combination of penetrating oil and carb cleaner.
Now I went to put the push rods back in and I can't seem to get the push rods on the cam. They either go too far down or not far enough. Is there a trick to getting the push rods in or will I have to take the whole rocker arm assembly off to get the push rods in?
Thanks for any and all advice,
Noah
Noah
