Farmall300 ta
dewy
On throw out bearing an ipto input couplin do you grease that...also the throwout bearing shaft that holds throw bearing assembly ,what do yall thinks better anti seize or grease on shaft...mine was so rusted i had to cut it out....thanjs dewy
Most of those old tractors had grease fittings for the cross shaft and throw out bearings. As for the pilot bearing some of those had a grease fitting in the flywheel to grease them you just have to turn the engine over till it shows in the hole at the bottom of the flywheel housing.
Only thing grease able for the TA is the cross shaft. Throw out bearing is sealed. Not sure what you mean by, you cut it out??
Cross shaft.was rusted so bad had to cut in two places...had to get new one from salvage yard....dewy
