(quoted from post at 03:21:56 12/17/14) They all work fine but I've found nobody refills the brands with plastic valves.
(quoted from post at 15:03:25 12/17/14) by far the most used extinguisher in my Engine company is the water can--just holds water and pressurized with air--used when ever we don't need a hose line.
(quoted from post at 22:15:31 12/16/14) What fire extiinguisher (size & type) would you recommend for a 22x34 wood lined shop? Welding, mechanical, auto body, etc.
Thank you,
Glenn F.
(quoted from post at 02:54:41 12/19/14) Using a water based extinguisher on a liquid petroleum fire can cause it to spread as it will float on top of water.
(quoted from post at 05:54:41 12/19/14) Using a water based extinguisher on a liquid petroleum fire can cause it to spread as it will float on top of water.
(quoted from post at 07:11:59 12/18/14) Halon is no longer in use... at least not in new fire suppression systems.
Rod
(quoted from post at 07:08:27 12/19/14) That's what Class B foams such as AFFF are used for... petroleum fires. That said... AFFF is another product that I believe is no longer on the market...
Rod
