flembo
I inherited a 1710 about 4 yrs. Ago that belonged to my FIL. The Differential Lock hasn?t worked for many yrs. I seem to recall him mentioning that the shift fork was broken I don?t know if he knew that for sure or just assumed it was broken. The differential lock not working has not caused me any problems but I would like to fix it if I can, just so that everything works as it should. I have the FO 44 manual that shows the exploded views of the differential showing the Diff. Lock pedal the cam pin, spring and fork. What I can?t tell is if I could get at it by removing the lift arm housing. When I push down on the pedal it does spring back making believe the cam pin is not broken or missing and that the notch in the fork is functioning. Long story short has any one ever worked on one and can give me some advice as far as how best to go at it. I know parts are hard to come by for these tractors but I did find and buy a used fork and a spring just in case. Thanks for any help.
