We have a Ford 1920 in the shop that came in for clutch work (PTO would not dis-engage) and we ran into a somewhat serious problem. We pulled it in the wash bay and after giving it a good pressure washing from top to bottom it would not run right, it missed and it smoked way more then it did prior to the wash job.It also had a rattle or ticking noise in the engine it never had before. We looked at a bunch of different things and after we figured out what happens it all made sense.......the front (#1 port) intake gasket was sucked in and when we washed it water got down in #1 cylinder (the port is on top of the head, not the side) and it now has a bent rod. The noise cam from the bent rod contacting the block and the miss and smoke was from the lowered compression. I have located the parts and I think if I had some torque specs I would have what I need to get it together. I have an older I&T manual and it has spec for a 1910 and a 2110, but it does not look like they use the same model of engine, which according to Tractor Data is a Shibaura model N844 in this 1920
Would you have the following specs available?
Rod bolt torque
Head bolt torque
Rocker arm housing bolt torque
Valve lash specs?
Thanks!
Rod bolt torque
Head bolt torque
Valve lash specs?
Thanks!
