Hi all,
I have an issue with the hydraulic controls on my 3600. With the controls removed the concentric shaft is visible. The outer shaft (draft) is moving freely of the inner shaft and working properly. The inner shaft (position) doesn't seem to want to move. If I put a spanner on it it will raise and lower the lift arms but there is at best about 10 degrees of movement on it. It springs back to the lower position which looking at the manual would appear to be right - the friction disc holding it in place normally i'm guessing.
Has anyone any ideas before I commit to removing the lift cover? - given that I have a cab this is more complicated that normal
Also, if I end up removing the lift cover what would it be worth replacing at the same time?
Cheers,
Graeme
Cheers,
Graeme
