lastcowboy32
I've had my 4000 parked outside all winter. It has a cap on the muffler, so I don't think this is a water ingress issue, but here's the story:
I've had it parked next to the barn, so I can plug in the inline water heater (It has a heater in the lower radiator hose). The generator has been bad for a couple months, but I've left it alone and used the tractor just a couple of times to plow snow (then I put the battery on a charger to make sure it's charged back to snuff)
Anyway, I got the generator off yesterday and had it rebuilt. I put the generator back on today, and started it up. It started fine with no heater, the outside temp was about 50.
I had some antifreeze with me, so I topped off the antifreeze while it was running... it uses maybe a half gallon of coolant every...oh...I don't know...say 20 to 30 hours of operation.
But, I had to shut it off after a couple of minutes to retension the generator belt.
When I went to start it again, the starter balked.... the solenoid clicked... but no real turning..
then I tried again...just a couple of turns
then I tried again...boom, started right up like always.
BUT, it seeped maybe a half pint of black oily/watery/milky crud out of the exhaust manifold.
I let it run about 15 minutes to check generator function and make sure the battery recharged. It ran no problem.
It seems to me that one of the cylinders must have wet stacked? It got plugged up with some fluid that wouldn't let the piston rise?
Now...this tractor ALWAYS starts well. I have never used ether. I don't need to plug in the heater until the temperature is maybe down into the teens or twenties. It doesn't need glow plugs.
But... it always steams from the exhaust manifold (or possibly head gasket just below the exhaust manifold...hard to tell) when it first starts up. After about five minutes, it's always running clean as a whistle. No smoke...nothing.
Is this engine just having a little head gasket leak or wet stacking issue initially after a cold start?
I've only had this tractor for a year, and it's been just about free of any trouble. Always runs fine...just... like I said... It always seems to spit out some oily/watery/black crud and steam/smoke just a little bit with a cold startup.
Is this typical? A sign of trouble? Something to watch?
