RedBarnFarm
Hoping someone can guide me to another possible answer on a long-term reoccurring problem with my shuttle shift. So the history is the tractor developed an issue where it was slow to engage in reverse or would only engage at high rpm after 10 or 20 seconds, forward was fine. Had a mechanic work on it and they split it and went through and replaced seals. Got the tractor back and had the same issue after about an hour of running it then the shuttle shift would no longer move. So here is what I have done since then -
I checked the fluid and that was good, opened the access panel underneath and checked all the linkage and didn't see anything wrong there. Turned the tractor back on and looked in the panel and things are spinning.
With some forum help I was directed how to remove the blocker valve and change the pins, seal, and springs. I did this and bam, everything worked great for a couple of months. Granted I wasn't using the tractor extremely long periods of time or in extremely hot weather.
Now that we have hit hay season I started loading and move bales with it and it has gone back to only engaging in reverse at high rpms after a delay, on top of that now it does the same thing in forward which is a new symptom. It was mentioned in my last post about the blocker valve if it didn't solve the problem it might need to be split and look at the oil diverter - is this now the likely culprit or since it did go back to working for several months could it be something else? It is 100 degrees here and I am running mostly early morning late evening but it is still probably in the 90s. Any thoughts?
