tysmobiletractor
I have this good old 641 Ford 4cylinder gas engine.
Been running weird last few times I used it. Don't use it often.
Now it missed really bad if you try to give it throttle.
What I've done:
New-points-condensor-rotor-cap-wires-plugs-pulled the carb and disassembled and cleaned it - reinstalled - new fuel filter-tank is clean- lots of gas flowing to carb-
just reset the timing -
sprayed around intake while running to see if there is a intake leak-nothing obvious
Starts weird when cold - I think because I give it a bit of throttle to get it going. Idle and up to about 400-800 rpm runs great- above that missed terrible!
When its warm it starts great with the throttle low. Runs perfect at idle and just above.
Is there some sort of advance in the distributor that could do this?
Just seems electrical.
If I fool with the distributor timing, I can get it to run better at mid higher rpm, but never the way it should.
What I've done:
