The tractor ran like a top the past
couple years. This year it was starting a
little hard, so I decided to replace
points, condenser, cap and plugs. Now I
can't get a spark from the distributor at
all.
I've followed many threads on this site
trying to resolve this to no avail.
Here's a quick summary:
Set new points to .025 on the dot.
Found TDC using the thumb over the
cylinder trick and rotated flywheel to
24? BTDC.
Holding the cam lobe at full advance, I
rotated the distributor counterclockwise
until the points just open and stabbed
the distributor.
Put dust cap, clip, rotor and cap back
on. Grounded #1 spark plug. Key on and
hit starter... NO SPARK.
Moved #1 plug wire from distributor to
capacitor and tested again...GOOD SPARK.
Moved #1 plug wire back to distributor
and loosened distributor bolts. Moved
engine back to 24? BTDC. Grounded #1 plug
again and rotated distributor to achieve
static timing. GOOD SPARK while rotating
clockwise. NO SPARK while rotating
counterclockwise. Tried starter...NO
SPARK.
Given that the cam on the inside rotates
clockwise, I was expecting to rotate the
distributor counterclockwise for static
timing. However, when rotating
counterclockwise, I can here sparks
jumping around inside the distributor and
sometimes sparking where the distributor
meets the block.
I also noticed that one of the contacts
in the NEW cap is worn already indicating
a bushing issue in the distributor. Not
sure if this would cause the symptoms
above. The successful static timing spark
is throwing me for a loop.
Please help!!!
all.
24? BTDC.
the distributor.
SPARK.
meets the block.
Please help!!!
