I have a 641 with a TSX 765 carb that was just rebuilt. I replaced the points, cap, rotor and condenser and I am getting good spark. I took off the tube to the air cleaner so I know I'm getting air and there is fuel. The tractor doesn't even want to try to start but it does tend to flood so bad that gas leaks out of the intake. I am guessing that either when changing the points I threw the timing out or the adjustment screws on the carb are out of adjustment. What are the proper starting adjustments for this particular carb? I read 1.5-2 turns out on the main adjustment screw (a) 1 turn out on idle(b) and 2 turns on the bottom screw(c), is this correct? Could I have messed up the timing when doing the points? Is my 6 volt system just being a pain?
