mikewood869
Our 1982 Ford 6610 is putting out too much radiator pressure and is just blowing it out of the overflow tube after a 1/2 hour or 45 minutes at pto rpm of run time. After 6 hours of run time, I had to add a 3/4 of a gallon to get the coolant level at the top of the cores. I was thinking that the tractor needed a new thermostat, but when I pulled off the thermostat cover, there was no thermostat in there. I put a 188 in for giggles and now the tractor will start blowing coolant, that takes 10 to 15 minutes or less of pto rpm to start releasing coolant. The fan belt is tight, the water pump doesn't have play in it, I put a different radiator cap on it (there was a 13 psi cap so I tried a 16 psi that I had lying around), and that didn't work. There's also not that many bubbles when you first fire up and watch the coolant move around in the radiator. There is no water in the oil, but there is oil in the radiator (the radiator cap builds up oil). Would it be time to do a head gasket again or do I need to get something tested? There is a good amount of blow by and if you plug up the valve cover breather tube, it will shoot out a paper towel fast.
