(quoted from post at 10:33:08 04/10/23)
The flywheel & clutch assembly is available not the rest of the donor tractor.
Do you think I need anything else?
(quoted from post at 14:51:03 04/10/23)(quoted from post at 10:33:08 04/10/23)
You will need to go through the parts pages very carefully. The 860 PTO shaft runs from the clutch through the transmission to behind where the engagement lever is, while the 850 shaft drives off the back of the transmission. I am just finishing swapping out an SOS for a 960 five speed but I am swapping in from the rear main back.
(quoted from post at 14:27:37 04/10/23) Forgive my ignorance, what is SOS?
I will look through the manual again.
Thank you
/quote](quoted from post at 14:51:03 04/10/23)(quoted from post at 10:33:08 04/10/23)
The SOS is another old Ford tractor transmission.
(quoted from post at 01:41:21 04/11/23) You will also need nose cone and input shaft if your clutch
dont have double hole need one of those too. Probably a
few more things its been a while since Ive done one Easier
to just swap in the 860 trans. As Showcrop said compare
parts in the manual
(quoted from post at 12:33:16 04/11/23) This a 901 series (actually, the first picture is a 960, the rest are a 961...), but basically the same as your 800 -
Thank you for these pictures, I think I can split it once I remove the 710 loader. Now I need to see if I can use the 5 speed with live pto or if I need to rebuilt what I have. Nice pictures.
I block the engine and roll the rear to split.
I built a custom table with casters to facilitate transmission movement.
There are two seals associated with the input shafts, do yourself a favor and replace both of them. Also check the condition of the needle bearings fitted inside the larger shaft.
(quoted from post at 09:40:03 04/19/23) Okay, I have made a lot of progress but now am stuck on the tear down and want to make sure I don't bust something.
I have split the transmission from the engine. I have completely removed the floor boards, brake and clutch pedals and linkages. I have removed the PTO shaft from the rear axle and also the PTO shift plate on the left side. All fluids are drained and I have removed the bolts connecting the transmission to the rear end.
I can seem to split the rear end from the transmission. Am I missing something? I have looked over the manual twice and I don't know. Is this just 68 years of being stuck together and multiple coats of paint or ???
Thank you
There is a gasket in between the two cases so it is going to take force like a slim chisel or large screwdriver driven between to break them apart.
/quote](quoted from post at 12:33:16 04/11/23) This a 901 series (actually, the first picture is a 960, the rest are a 961...), but basically the same as your 800 -
(quoted from post at 20:14:20 04/20/23) Did you get it? It's been a few years since I did the pictured transmission overhaul and I don't remember having any issue splitting the transmission from the rear end.
