Ford 861 powermaster pops out of gear
If your lucky you may get by with a new plunger and maybe a spring. Some times they will wear a groove into the shift rail Which would require transmission removal.
Mark
Replacing the detent balls and springs MAY help a bit, but the symptom is caused by worn engaging teeth on the shift collars. In order to eliminate the problem completely, new shift collars will be required and these are long since NLS.
