datacommand
I've seen YouTube videos about replacing the seal and bearing on an 800 series tractor. I've also seen a few on the N series tractors.
One video on the N series tractors said the PTO lever should be engaged to keep the spline in place as the shaft is removed, otherwise it might drop down. The videos also showed the broomstick handle trick to raise it back up.
I am about to pull the PTO shaft on my 861 and was wondering if the PTO lever should be engages on the 800 series tractors as well. Or does it matter, engaged or not. Have not seen any 800 series videos mention it, but didn't want any surprises.
