mpdhorsecop
I"ve read about the shut off valve, seen the shut off valve, changed the shut off valve. Know that the screw in, or lever type will fail, eventually. Read about changing o-rings and drilling out pins and routing lines every place. Believe the shortest distance between two points is a straight line. Is there a way to have a fitting were the shut off valve goes under the tank to the carb with a shut off at the carb? Second question, just because I don"t know, are the two mounting wholes, were the shut off valve goes, dead ended or do I have to plug them if they are not used? Thanks fella"s!
-Experience is always the best teacher
