gas shut off valve
LDoyle
My shut off valve was leaking and missing the screen inside tank so I bought a new one from TSC . Installed it , put gas in tank , opened valve .......and nothing .Thought maybe because tractor was on a angle maybe tube was above gas level so opened all the way for the reserve position and ......nothing .Loosened sediment bowl ( I don t know why ) and gas began to flow . Tightened bowl up so it wouldn t leak and gas flow stopped . Vacuum locked ( ? ) so I remove gas cap and ......nothing . This is driving me crazy. Think I will return it and get another . Anyone ever have this happen ?
Would you believe your problem is all in your mind?? Why do I say that well it means the float valve in the carb is shut because the carb is full of gas and till it opens gas can not flow because the sediment bowl is also full. Now I know you say full of what right??? It is full of air and two things can not fill the same space at the same time. Open your shut off up 2 turns start your engine and I bet in a minute or 2 the sediment bowl will fill with gas
Friends and I had a cut down Model A Ford.If you ran out of gas you could not get going again until you loosened the fuel line at the carb bowl.Once some gas appeared you tightened the nut and the engine woulds start.Same thing happened with my tractor while picking up brush with the carryall.Ran out of gas,put in 2 gallons.No start.Sprayed a little starting fluid in the air intake on the side of the hood.Start up and ran fine.Cant explain this.Can air in the line hold back the gas flow/I think it can.My bandsaw mill has a gravity feed blade coolant system.There are times when its hard to get the water flow started.The tubing is clear and you can see air bubbles moving upward in the line when water flow is OK.Tank is vented and 5 feet above the discharge.A small amount of detergent is used and windshield washer fluid is used in freezing weather.You have to careful to not let the tubing empty or you will have trouble starting the water flow again.
My sediment bowl works overtime sifting the remaining crud out of my tank. Every time I drop the bowl to clean it and turn the fuel back on the bowl remains empty until the motor is running.
Well , I sure feel stupid now , but hey , if you don t ask questions how will you learn ? I will try to start it tomorrow and see first hand the wisdom found on this forum . Thanks guys .
Well that is why there is never a stupid question. The only time one is stupid is when they do not ask and if you do not ask then you do not learn.
