Sediment Bowl Question
It seems improbable that they are permanently fixed to each other. The threads that work when operating the valve should be the connection between them. It is probably over-torqued against the back seat. If I had it, I would probably clamp the inner nut in a vise then put a wrench on the handle and twist it clockwise until something happens.
I agree.....it seems nearly impossible for the nut to be stuck 🤔
I do the redneck modification. Those filter bowels were old school and all they had back then. They bend and leak, The screen gets lost they do not filter well on a good day. I never liked those metal inline filters, they were made for pressurized systems. I use small see through filters for ATVS (they are for gravity systems) available from Amazon by the dozen for cheap. Also 1/4" FUEL LINE hose. A couple of brass npt to hose adapters and Bobs yer uncle.
Not all metal filters are for pressure, Napa 3031-1/4”, 3032-5/16”, 3033-3/8” are all I use on tractors. I won’t use a plastic one, can’t have the liability on a customer’s tractor.
As far as sediment bowls, I quit using them 30 years ago, appropriate fittings, ball valve and the right size filter. Much better, no gasket or screen and bowl to clean. No hassle changing a filter, 2 minutes and done
