Sediment Bowl Question
VFMerc
I recently had my H go through major service. During the service the sediment bowl was replaced. I found the packing/washer associated with the handle damaged but my question concerns how this handle operates. When I open the valve handle, both nuts turn with the rotation of the handle. If the entire lever assembly moves away from its seat, what is the purpose of the outermost nut?
Also, when I was defueling the remaining fuel in the tank, with the valve in the "closed" position fuel continued to drain from the tank as soon as the bale on the sediment was loosened. I defueled the tank completely with sediment bowl in place but loose. This leads me to believe the handle in the closed position was not completely seated.
Is the assembly defective if the nut closest to the sediment bowl turns with the handle and does not hold its position and the packing/gasket against the sediment bowl assembly when the handle / valve is opened?
The packing nut around the shut off valve should not move when shutting fuel on or off. Nor should fuel flow with the valve shut off. It sounds to me like the packing material inside the nut is sticking to the nut. You will need to remove the nut and clean the shaft of the shut off and the inside of the nut. Their are several materials made to use as packing, I like to use silicone string. Silicone string or thread is very slippery and allows the valve to be opened or closed without the nut turning.
Dave
Thanks. It appears to be a defective assembly as it is new and the handle can’t be turned without the nut moving even when I place the nut in a vice and attempt to disassemble. I will replace. I will locate some silicone string.
I find these after market leak do to design . If you open the needle to far like one turn open any further the thread cut up the seal and it leaks . Hope you kept the old sediment bowl . Your can build the oem sediment bowl valve . If not then I done think this was not much help to ya.
We have bought and used dozens of new sediment bowl assemblies ( on dozens of Farmalls). We have bought them from tractor supply, rural king, napa, Steiner, YT, and gasp, don't say it .... Amazon 🧐. Zero, zero issues with any of them. Never any leaks. Amazon is by far the least expensive. We have also repaired many originals , not much to them. The top can be bent out of shape and ruined or the innards can be corroded beyond saving. Repacking can be wax string, yellow thread tape or a gasoline rated o ring. The key to long life is never over tightening when you open and close the valve 😀.
Who ever performed the "major service" boogered that all up 🧐. Hopefully that's the only issue they caused.
I tend to agree. What is the o-ring doing on the outside of the first nut in the OP's pictures? The first nut has a pipe thread on the outside. Put some pipe sealer on it and screw it in. Once it is in place, it should never turn until it needs to be removed again. The valve itself has 2 seats. One shuts it off when the stem is turned clockwise and it reaches the seat inside the housing. The other is a back-seating valve. The seat is on the inner end of the first nut. When the stem is turned fully counterclockwise it seats against the nut. If this valve is in good condition and the valve is fully open, the valve should not leak even if there is no packing under the second nut. The packing only keeps it from leaking when the valve is partly open. And that should only happen briefly while you are actually opening or closing the valve. Packing under the second nut can be done with any of the materials already mentioned. Don't tighten the second (packing) nut very much. It just makes the valve turn harder, which makes it more likely for one or both nuts to turn when the stem is turned.
Thanks Jim. I don’t have the original and probably could have cleaned and reused. I have a replacement on order. When it arrives I should be able to confirm that the one installed is defective. The nut closest to the bowl housing appears to be seized or manufactured solidly attached to the valve handle. Thanks again
Please report your findings when you compare your newest purchase to your defective one. This is interesting.
The installed sediment bowl was a defective manufacture. The handle is..fixed to the inner most nut. When the valve is opened the nut closest to the bowl assembly turns with it whether the handle is turned clockwise or CCW. The replacement received today ($15.15) confirms the assembly removed is a manufacturing defect. The replacement works as intended, specifically, the both nuts remain in position as the handle is operated.
The sediment bowl was a defective manufacture. For some reason the handle is mechanically connected to the inner nut and backs out when handle is turned CCW and in when turned CW. The replacement works as described above. I'll save your info should I need to repack the new one and return the original to the repair shop.
The sediment bowl was a defective manufacture. For some reason the handle is mechanically connected to the inner nut and backs out when handle is turned CCW and in when turned CW. . . .
It seems improbable that they are permanently fixed to each other. The threads that work when operating the valve should be the connection between them. It is probably over-torqued against the back seat. If I had it, I would probably clamp the inner nut in a vise then put a wrench on the handle and twist it clockwise until something happens.
They better hope the float doesn't start leaking.
Seems like they are fixing a small issue, but creating a potentially bigger issue.
He said gas on a rubber hose is not good. Then he goes ahead and does this. He could have at least swapped the locations of the filter and the valve so the valve could be used to service the filter without draining the tank.
