(quoted from post at 20:34:41 07/19/10) It does not have straight cut gears, and there is no clutch to be dry or dirty. .
What do you call this on an HPX ? Looks like a clutch to me.
AM135537 CLUTCH 1 DRIVE, (SUB FOR VGA12187)
While the gears do have some helical slant on the cut. There are NO syncros.
1 CH13511 BALL BEARING 1
2 R91141 RING 1
3 M810818 WASHER 1
4 M810761 GEAR 1 INPUT
5 M810760 SHAFT 1 INPUT
6 MIU801668 BEARING 1 (SUB FOR CH13508, THIS APPLICATION)
7 19M7868 SCREW 16 M8 X 30
8A M810738 BREATHER 1 - 040000
8B M811569 BREATHER 1 040001 - XXXXXX
9 AM881529 DIPSTICK 1 - XXXXXX
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
10 M810640 DIPSTICK 1 - XXXXXX NLA, (SUB AM881529)
11 CH10570 O-RING 1
12 CH18306 PIN 4 - XXXXXX
13 M810727 DRAIN PLUG 1 - 040000
M811712 DRAIN PLUG 1 040001 - XXXXXX
14 M811593 WASHER 1 - XXXXXX
15 M810758 HOUSING 1 - 080000 RH
MIU801473 HOUSING 1 080001 - RH
16 MIU801250 HOUSING 1 - 080000 LH, (SUB FOR M810757)
MIU801439 HOUSING 1 080001 - LH
17 AM881528 PLUG 1 - 080000 SPEED SENSOR
MIA881439 PLUG 1 080001 - SPEED SENSOR
18 M810844 PLUG 1 - 080000 NLA, (SUB AM881528)
MIU801471 PLUG 1 080001 -
19 CH10570 O-RING 1 - 080000
MIU801472 O-RING 1 080001 -
20 M806721 SLEEVE 1
21 LVU800930 SEAL 1 - XXXXXX
22 19M7818 SCREW 2 M12 X 80
23 LVU13981 SPACER 1 (TOP MOUNTING HOLE ONLY)
24 14M7401 LOCK NUT 2 M12
25 R44302 TIE BAND 1 040001 -
26 TY22552 BULK HOSE 1 040001 - BREATHER (14.6")
.. AM135238 TRANSAXLE 1 - 040000 REAR (W/BRAKE ROTOR) (SUB COMPONENTS) (SUB FOR AM132521)
.. AM135192 TRANSAXLE 1 040001 - 070000 REAR (W/O BRAKE ROTOR) (SUB MIA11443) (ALSO ORDER RE517370)
.. MIA11443 TRANSAXLE 1 070001 - 080000 W/BRAKE COMPONENT (UV31-4D)
.. MIA11590 TRANSAXLE 1 080001 - W/BRAKE COMPONENT (UV31A-4D)
