jaoneill
I could use a bit of help with my latest dilemma. Power went off last night and the way the sky was lit up with arcing electricity off to the northeast it was a sure bet that it wasnt going to be a 10-minute outage, so I fired up the genset. We have a 5k military unit powered by a 2-cylinder Onan diesel with just 2k hours on the clock; it's a slow turner (1800 rpm) designed to run continuously for weeks on end. It is more than adequate for all of our needs (usually runs at 15% - 25% capacity) and absolutely sips fuel. I woke up about midnight and we had lost power. Went out to the mechanical room and found the diesel barely idling and surging somewhat; a classic fuel issue. The fuel filters had less than 100 hours on them, as did the three electric lift pumps that I had replaced a couple of years ago. Traced it back to a screen in the fuel tank that I had no idea was there, easy enough to remedy. Fired it up, warmed it up, flipped the electric switch and nothing happened, as in zero, zilch, no power. I did notice last night that when I first fired it up, I adjusted the throttle to get the frequency at a stable 60, but in spite of turning the voltage rheostat all the way up, I couldnt get voltage over 110 although it usually runs at 120 in the three quarter position. Any suggestions as to what the issue might be?
This post was edited by jaoneill on 12/12/2021 at 02:20 pm.
![mvphoto85718.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto85718.jpg)
