Stoegs
Have a WD with a Gleaner E in it, is there any dimensions on the length of the rods for the governor for pulling, I read in a forum somewhere that the combine is different than the D17. Thanks for any input.
What’s the rod ratio now ? What you looking at doing shorter ? or longer ?
Front control rod is 26 inches, rear control is 6 1/2 inches. It could be correct, but the governors are set different for a combine and this motor is unchanged since it was installed in tractor, I think it should be changed but I have no clue. In fact I don’t know what else should be changed. I bought the the tractor just as it was finished. I have always had JD’s, this is the first AC, I am reading manuals and forums to learn. So any advice would be appreciated. Thanks Bill
