bwillett
- Location
- West Central Ohio
Pulled the engine after some discussion with my mechanic friend. Ground the edge of the pressure plate so it would slide into the flywheel with out binding, reinstalled the pressure plate and the fingers looked better, as in they were farther away from the clutch surface than when we started. Checked everything in the bell housing for correct fit and alignment. pulled the clutch release bearing carrier to see why it was binding. The clip that holds the carrier and the forks together was too tight on the fork and would not let it work. Changed the clip out for the old one and it worked......Put the engine back in and could not get the bellhousing within 1/4 inch of the back of the engine. Looked at the clutch and the fingers of the pressure plate were holding it out. Ran them in and bolted up the engine to the bell housing, re-adjusted the fingers to the proper gap, and it is all good...
Now to get the rest of the tractor back together...... Back on it Monday.
