Its built out of, say 2 X 12 X however long one would want it. I could see makeing it out of 20fts, but it might miss some low spots in the field, where 2 sections of 10ft ea might work better but make somewhat of a less even field.
Its made by laying down a plank, and then one overlayed onto the first by say 4in, and this continued down to whatever width one wanted it to be, and nailed or bolted together.
Said to be superior to any tool for makeing out a flat area, and also for use in gardens and for fields for sowing fine grass seed. 2 holes, or 3 for long lengths are drilled midwidth of the board and, I would imagine chains were bolted on the underneith of the first board, so as to raise it while being pulled to keep dirt from building up at the leading edge. Its supposed to crumble and pulverize clods into smaller and smaller pieces as they are passed down from front to back.
It seems like, if it was braced for it on top, that one could drill holes front and back. Seems like, if one pulled it with each boards front leading edge hitting the dirt, instead of the way ive seen it drawn to be used, that each 2in board would hold a length of 2in of dirt, the length of the boards, and that would/could be disposited in any low place, each board as it passed it thereby raising the low spots, and lowering the high ones. Any thoughts?
