Working on Grandpa's M Farmall for a young man and the control lever for the Heisler live power hand clutch is missing. If you have one on a tractor some pictures of it to use to fabricate one would be a big help unless you know where one is that is for sale. From pictures I found there appears to be 2 different style levers, mine is the style that pivots with a ball socket in the top of the live power clutch housing. The other style pivoted on a shaft that had a bracket attached to it that bolted to the top of the rear end cover.
Also looking for service info, parts breakdown or any other printed information on this pretty rare add on would be appreciated.
I am in the process of tearing this down and have it part of the way apart and am down to removing the brake drum. I looks to use a snap ring to retain the brake drum on the drive bull pinion drive shaft, but I have the snap ring removed and the drum seems pretty tight to the shaft and I don't want to break the drum by getting too forceful with it. I am not sure if this is the way it is meant to come apart or not, anyone have any info the would be of help with this?
A search on this site for Heisler turned up a post where a member here by the name of Nebraska Kirk said he dealt in parts for these Heisler live power unit, anyone know if he is still around and how to contact him?
Thanks!
Thanks!
