While pulling a disk with my dad"s 1940 9N he purchased about 4 years ago, the engine went into to turbo mode. Quickly turned the key off and found the linkage from the govenor to carb off. Put it back and made a couple more rounds, same thing. Picked up a new linkage and it did it again, except this time the linkage was still on. Now it wouldn"t start. Found distributor not turning, no spark. Looooong story short, found teeth on pressed on timing gear damaged. Had to replace with bolt on gear and different cam shaft. Govenor never did seem to work right when pulling a load, so took it apart and found shaft broken. Suspect this was the start of all the problem. Picked up a nice used govenor and installed it with new plugs, wires, cap, button, points, & gaskets. Cleaned out the inch or so of sludge from the oil canaster, drained the black 30 year old oil, new filter, and grabbed some 5w30 off the shelf.
BTW, I am by no means a mechanic. I can read, turn a wrench and it was either try to repair or junk it. I didn"t feel it was worth, and couldn"t afford, spending a bunch of money on it. I did buy the IT manual, but thanks to this forum and all the post and replies, I made it through the repair. Cranked the engine a couple of times for about 5 seconds to get some oil flowing, turned the key on, and first pull of the choke, she started. Smoked, till the oil burned off I had squirted on top of the pistons and valves. Missed a little, then leveled off and was purring like a kitten. Nice oil pressure, about 3/4 the way on the unmarked scale, right where it had always been. I was so happy and couldn"t wait to get back in the saddle again. Took her for a spin around the lot, then down and back up a little hill to see if the govenor was working. It was working good. Finished bolting down the hood and installing the grill. Went to move the disk out of the field where she had broken down. Dropped it and headed back to the house when I started hearing a knock. Looked down and the oil pressure was gone. Quickly shut it off.
Was still full of oil. Removed line to oil pressure gauge and no oil pumping. It"s back to the forum to troubleshoot a new problem. Got some 90w gear oil to squirt in the oil pressure relief port to prime the pump, tried that a couple of times with no luck, then drained the oil to have a look at the pick up tube. It is nice and solid. Tried spraying some WD40 down the port. It did come out of the drain hole after a bit, but not out of the pick up tube. Not sure how it got out elsewhere ? I suspect the housing is a sealed unit but don"t know what it looks like other than the break down in the manual. Ran a wire up the tube about 14 inches to see if it had sucked up some sludge and stopped it up, but got nothing out. Tried turning the engine over with my finger over the pick up tube, but no suction. If I spray the WD40 long enough, it will start coming back out of the pressure relief port. It seems to me that somthing is clogged up. Do I dare try to get some de-greaser down the port ? Try to force some air down it ? I don"t want to create more trouble. I can"t believe the pump just quit like that. I know the manual says the drive gear is fiber, but I remember it being shinny steel when I had the timing cover off, and it didn"t look damaged. I"m betting I created this problem by changing the oil and cleaning the sludge out of things. There was no screen on the oil drain. I have one ordered but it"s a little too late now. Any help at all would be greatly appreciated.
