I just recently purchased this ford 801 with the 2.8 gas engine. I put new points and condenser, spark plug wires and spark plugs. I drained the tank and put a new fuel settlement bowl on. I also just rebuild this carb throughly and it is spotless on the inside. The tractor will start and run on starter fluid but won t start by it s self. I have drained the bowl and it is filling up with fuel so I know the needle isn t stuck. Also if you cover the intake with your hand and let go it will start for a second. I have adjusted the needle screw on the carb and it doesn t do squat. What s next because I m kinda running out of places to turn other than buying a new old stock carb and I d rather not spend the $400.
